For a recent addition to our house, I installed a Ruud/Rheem 3 ton heat pump - it had R-410A refrigerant and 10kW heat strips. I installed a Hunter programmable Auto Temp Heat Pump thermostat.
All summer, it seemed to work fine for air conditioning. This is my first programmable thermostat, and I think I liked it for summer. Now, I'm not sure about cooler weather, but that's the source of my question.
It seems that now that the heat needs to run, anytime that the unit runs, the heat strips are running. I basing this on how warm the air is from the register, as well as how fast my electric meter is spinning! I''m wondering if I have something mis-connected in terms of wiring.
This is how the unit is currently wired:
Function Label(Tstat) Wire@Unit
24VAC supply R Red
Compressor stage 1 Y Yellow
Auxiliary Heating W Black & White
Emergency Heating E (Jumpered to W @ thermostat)
Reversing Valve O/B Blue
Fan G Black & Green
24VAC Common C Brown
I don't know if any of this makes sense, or if I need to get some more information together. I just know it appears as though when the heat runs, the strips are running as well.
The other unit that services the old part of the house is a Ruud/Rheem split system heat pump (the new one is a package unit). It has an old, non-programmable, manual thermostat. When I turn it to "Heat", just the unit runs; if I want the heat strips to run, I have to turn it to "Emergency". With that unit, I can feel a big difference in air temperature when the heat strips are on and when they aren't.
I've also read that some programmable thermostats will use and "Auto Recovery" feature, and if the difference between the current temperature and the desired temperature is too great, then it will activate "emergency heat". I haven't investigated this portion yet either.
Some of this is coming up because it is just now getting cold enough for the unit to need to heat, so I haven't had a lot of chances to see what's going on with this. I was just hoping to solicit some advice in case anyone was familiar with this situation.
I appreciate any help anyone can provide.
Thanks in advance.
Good luck and take care.
24VAC supply R Red
Fan G Black & Green
Thanks in advance.
