Plow Mount-Chain Float or Hydraulic Float
   / Plow Mount-Chain Float or Hydraulic Float #1
dkhntr04
Northern MN
Deere 3720 Cab
I am going to start building a plow mount for my McCormick CTV28 within the next few days. I'll be running an old 6' Westin plow from 1950's Jeep that I will be widening to around 80-84" to fit the wheel track on my new machine. I used the same plow last season on my Kubota B2400. On the B24000, I made a chain type mount where the plow was lifted by a cylinder via a chain to allow some float. I did not have a hydraulic valve with a float position on the Kubota. My new McCormick has a FEL, and I will be using the FEL valve that has a float position for lifting the plow.
What would be your preference, hydraulic float or a chain float? I know hydraulic float will allow me to set the blade at a fixed height off the ground without the load pushing the plow upwards when the loader valve is in the regular neutral position. Beyond that, I don't know what if any benefit I'd have using hydraulic float over a chain float setup. For what it's worth, the plow is my secondary snow removal device. I'll be using it to bust drifts on my wind-blown driveway and for light snows where using either my 80" 2-stage Farm King blower or my 6' single stage v-style blower are impractical. The mount will be attached to the frame, I will not be going the FEL mounted plow route.
Any and all inputs are appreciated. Thanks :thumbsup:
   / Plow Mount-Chain Float or Hydraulic Float #2
We have a blade on the front of out backhoe at work. We have to use the loader float and it sucks. I have used a chain set up in the past on a tractor loader and would much prefer it. Actually if I were to make my own I would set it up with a chain float and be able to use the "dump" to be able to when needed put extra pressure on the blade for scraping. In other word I would have it so by angling my attachment linkage that at some point it would push down on the blade linkage/frame.
The problems with the loader float idea are #1 the weight of the loader arms is now on the blade, which lightens the front end. When you angle the blade you can not push as much snow without the front of the machine getting pushed sideways. Even under light loads we have to turn the wheels into the push a lot more than we had to in the past.
The 2nd issue is as you push, the heavier the push the lighter the front end gets. With our current set up more often than not the front wheels aren't doing much when we get to the ends of the parking lot.
Really both problems are related to not having enough weight on the front due to the loader being in float.
   / Plow Mount-Chain Float or Hydraulic Float #4
I tried the hydraulic float years ago when I first made my snow plow/blade setup...Did not like it and switched it over to chain lift. Also tied the loader arm mounted blade first, what a mess that was and a BIG PITA.
1) Hydraulic float did not let the blade float fast enough, I was either leaving snow or digging too much dirt. One bump under the blade...4 ft later the blade was back down leaving snow the previous 4 ft.
2) Bump the joystick or for whatever other reason the hydraulics comes out of float mode you now have a bulldozer, good for dirt not good for snow.
3) Stick the plow blade/frame in a snow bank and there you will sit. With the chain lift you can lower the lift take more slack out of the chain, lift the blade higher and go about your merry way.
4) Too much down pressure (out of float) and the next thing you know the front of the tractor is coming off the ground and no traction.
   / Plow Mount-Chain Float or Hydraulic Float #5
I've had a few winters now with my own Meyer swap as shown. When using float, the entire weight on the two shoes is the moldboard plus the A-frame plus the loader arms. With a chain float the weight on the shoes is less I think the float will be easier.
I felt there was too much weight and never felt quite comfortable with allowing it to float, especially on gravel. The Meyer, bought new, was previously on a Nissan Pathfinder and had fairly small shoes. This year I replaced the two small shoes with much larger ones.
Time will tell......
   / Plow Mount-Chain Float or Hydraulic Float #6
Looks like the same blade as my new plow I setup last year.
   / Plow Mount-Chain Float or Hydraulic Float #7
Gizme - yes it's the same. Nice job on your part!
By preserving the original tubular A-frame, lift arm, and chain you've maintained the OEM float.
Once I tore off a Meyer shoe last spring, I decided to beef them up. We welded on larger tubes right next to the old ones, and simply inserted the much larger shoes.
There are benefits to having no chain because I can control the moldboard angle of attack and I can pile it really high. I guess it's six of one or half dozen of another.
   / Plow Mount-Chain Float or Hydraulic Float #8
Mine is chain lifted, never tried it the other way, but as I suspected, according to others here, using the valves float feature does not react fast enough to allow the plow to freely follow the contour of the ground.
So my recommendation would normally be chain float. But only because you say this a secondary tool to bust drifts etc. You may want to go with the rigid lift link. I've personally never felt the need for it (well maybe occasionally), but the main advantage is the ability to apply down pressure, so in your case that could come in handy, plus ramming snow drifts with a plow in a fixed height could be an advantage as well, prevent it from riding up.
It would be fairly easy to swap between a chain and a rigid link, I've thought about it myself since I'm using a DA cylinder, but like I said no real need for me.
JB
   / Plow Mount-Chain Float or Hydraulic Float #9
Yepper, All about personal preference. I am sure it also has a lot to do with the surface you are plowing and the amount of snow you get.
   / Plow Mount-Chain Float or Hydraulic Float #10
The down pressure is important for me: I had to suddenly remove the bucket and add the plow two weeks ago when we had 12" wet snow. I'm in the middle of trenching a water line with my backhoe so I'm using the down pressure on the Meyer to lift the front wheels off the ground! I'm careful such that the load is not on the single pivot bolt but rather on the whole rigid A-frame I built.
By the way - I have no welder. The entire plow frame was first made up with plywood and then brought to the weldshop. They tacked it all and one final fit was made before final weld/paint.
2017 Nissan Titan SV Crew Cab Pickup Truck (A50323)
2017 Nissan Titan...
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
2015 Chevrolet Silverado (A50323)
2015 Chevrolet...
Massey Ferguson 65 Tractor (A50514)
Massey Ferguson 65...
2013 Mack GU713 T/A VacCon Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
