10 HOUR CHECK -UP??
   / 10 HOUR CHECK -UP?? #1
goatman
southern ohio
NH TC 30
I just read a post about 10 hour check up/ maint.. I have a -TC 30 with 15 hours other than check fluids should I change any thing?? thanks /forums/images/graemlins/blush.gif
   / 10 HOUR CHECK -UP?? #2
I guess with a new rig I would be checking the fluids just about every time I use it to ensure everything is ok. As far as maintenance, I don't think you have to do anything until 50 hours.
murph
   / 10 HOUR CHECK -UP?? #3
You may also want to check tightness of those bolts and nuts, especially on the wheels, FEL, and other parts getting the most action.
   / 10 HOUR CHECK -UP?? #4
My NH TN65D had FOUR loose bolts on the wheels when I checked at 10 hours and both bolts holding on the FEL had to be tightened up a half a turn or more. You must check all the nuts and bolts you can reach on a new tractor because sometimes they loosen up after the first few hours of use and sometimes they were never tightened! I just noticed the nut holding on the right side of the my seat belt was so loose that with a few turns it would fall off ! I've had similar experiences with other brands of tractors, so its not just one make or manufacturer that sometimes leave things loose.
Thanks to all that have replied.. I am going to check every thing tonight as I plann on using the bush hog all week end... /forums/images/graemlins/grin.gif
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
2011 GMC Sierra 4x4 Pickup Truck, VIN # 3GTP2WE36BG213306 (A51572)
2011 GMC Sierra...
JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
JCB 525-60T4...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR29J160609 (A51572)
2009 International...
2005 Blue Bird BB Conventional Bus, VIN # 1BAKBCKA45F219634 (A51572)
2005 Blue Bird BB...
New Long Forks (A53002)
New Long Forks...
