10 hp Briggs and Stratton problem
   / 10 hp Briggs and Stratton problem #1
fyrman1
I have a 10 hp engine on a 5000 watt generator. Its about 10 years old, mostly kept inside, used little. I got it out yesterday and ran it. It did start and run on bad gas...I changed it out to new gas and it ran rough for about two hours. did not overheat that I could tell. It shut off and I have been trying to start it again. It will fire up and run about 3 seconds and shuts down again. Eveything seems OK. Fuel is still making it to the carb. I took the bowl off and dumped out the gas even though it looked OK. Any thoughts what to check?
   / 10 hp Briggs and Stratton problem #2
The screw which holds the bowl, is the nozzle, too. Have You checked the small bore in the screw?
   / 10 hp Briggs and Stratton problem #3
Is your oil level too low? (your oil alert sensor is shutting down your engine?)
   / 10 hp Briggs and Stratton problem #4
carb needs adjusting; adjusting screw under bowl; counterclockwise to richen. try one turn to see if it runs, when it starts to stall , does pushing choke on try to keep it running? Also; is shutoff under fuel tank open? And the old favorite; "is the gas cap vented"
   / 10 hp Briggs and Stratton problem #5
Welcome to TBN fyrman.
Tell us...inquiring minds want to know. Did you get it running? You had several good suggestions. What was the problem?
Ted
I cleaned everything and attempted the adjustment and it still wouldnt run. I finally got a fuel pump and it ran for a few hours and stopped again. Ending up finding a newer engine on ebay for $75 and got that. Thanks for all the suggestions though....all good ideas.
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
UNUSED INDUSTRIAS AMERICA HI-900 HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
UNUSED MOWER KING ECSSCT72-72" HYD TRENCHER (A51248)
UNUSED MOWER KING...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
