100 hp tractor - Dirt pan size?
   / 100 hp tractor - Dirt pan size? #2
See the chart for HP requirements. Obviously soil type is an important consideration too.
Product - Dirt Pan
   / 100 hp tractor - Dirt pan size? #3
Also the type of pan, the simple cutting edge scoop type that more HP then the pto power self loading type.
   / 100 hp tractor - Dirt pan size? #4
We have a 36 year old 8', 2-1/2 yard dirt pan, called a level-all. We pull it with a 36 year old Hesston 105 HP 2 wheel drive. Loaded tires. Also put a 55 gal barrel of concrete for weight on front of tractor. If the dirt is really tight, we will normally either till, flat brake, or run scarfier teeth before loading.
   / 100 hp tractor - Dirt pan size? #6
Hmmm....... dirt pan. Around here it's either a pull or motorized scraper.
   / 100 hp tractor - Dirt pan size? #7
   / 100 hp tractor - Dirt pan size? #8
3 yard would work, next is 5yd & dont think 100hp is enough. Dirt pans pull hard when loading.
Told 25hp/yd??
That all depends on soil type and moisture.
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
2011 FORD F-650 ROUSTABOUT TRUCK (A52472)
2011 FORD F-650...
2019 CATERPILLAR 289D3 SKID STEER (A51246)
2019 CATERPILLAR...
Electric Concrete Mixer (A51573)
Electric Concrete...
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
2018 JOHN DEERE 672 GP (A52472)
2018 JOHN DEERE...
