Price Check 1020 MF 4WD 630 hours
   / 1020 MF 4WD 630 hours #1
Michelle K linnane
Esperance NY
JD 4103
Dealer has this tractor $4900 for MF 1020 it is supposed to be 4wd. What do you think for price?
   / 1020 MF 4WD 630 hours #2
Michelle,
Does it have power steering? I believe it was an option and is important with 4wd!
Dave
   / 1020 MF 4WD 630 hours #3
It does have a 4WD front axle...doesn't mean it works though.
Assuming everything works, what are you planning to do with it? Since it has turf tires and no loader, I'm going to guess it was used mostly for mowing.
   / 1020 MF 4WD 630 hours #4
I think the price is fair. You have to consider what you are going to be using it for. A to put a loader on it means more money along with switching to R-1 tires to suit your needs. It is gear drive which is far superior to hydrostatic on these models as the hydro was a big week point. I would also take a look at the shifter, lift up the rubber shroud and look for any repairs. These were prone to getting kicked and broken off and are hard to come by.
I offered the john deeler that had this in his lot $4700 for it and they would not take it. Well I have purchased 2 zero turns from
them and a tractor. I not sure if I will go back again. I sure this was a good thing after thinking about I would like 30 to 35 hp.
Go to mow and maybe use a snow blower with it.
NEW Ripper Shank (A53002)
NEW Ripper Shank...
14ft Bi-Parting Iron Gate (Cow Design) (A51573)
14ft Bi-Parting...
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
2008 Ford F-450 Crew Cab Service Truck (A52377)
2008 Ford F-450...
Electric Concrete Mixer (A51573)
Electric Concrete...
