1020 rear axle grease fittings...
   / 1020 rear axle grease fittings... #1
Blueflint
Winchester, Ohio
Deere 1020
On the top of the rear axle housing, out towards the wheel, there is a grease fitting. How much grease should be put in these? If routinely done, 3-6 pumps on the grease gun or???
Thanks, Tony
   / 1020 rear axle grease fittings... #2
About 5 pumps once a year unless a lot of hours are racked up. I greased my 4255 rear axle brgs yesterday
   / 1020 rear axle grease fittings... #3
Tx Jim, you seem very knowledgeable about anything related to JD tractors. I believe you said you worked at a dealership or owned one? Anyway I am new to tractors. Had my 5065e for 1 year with 75 hrs on it. I was reluctant about getting a machine made in India. I have had practically no problems and follow the book on maintenance. Am I likely to have more problems as years go by? Maintaining my 80 acre timber/hunting tract: roads, food plots, etc I will only put about 75-100 hrs per year. Is there any advice?
   / 1020 rear axle grease fittings... #4
I was employed by a JD dealer for over 21 yrs but didn't own one. Your tractor will probably be fine as good maintenance goes a long way foe equipment performance/durability.
2017 HYDREMA 912HM ARTICULATED DUMP TRUCK (A52706)
2017 HYDREMA 912HM...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A52706)
2001 INTERNATIONAL...
Miller Spectrum 500 DC Plasma Cutting System (A54811)
Miller Spectrum...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A53473)
2019 New Holland...
Miscellaneous Kitchen Equipment (A53117)
Miscellaneous...
