Buying Advice 1025R, 2032R, maybe a 3039R. Input please.
   / 1025R, 2032R, maybe a 3039R. Input please. #1
Hayseed Andy
Lake County, Florida
JD Z915B ZTR
I am trying my best to nail down what would work best for me. Each time I think I have the answer, I think of something different. Here is my current situation. I have 10 acres in Central Florida. 8 are roamed by cattle and seldom need any cutting. Only when the owner of the cattle fertilized did I have to bush hog with a borrowed tractor. 2 acres are sectioned off for my house. I have a Z915B Zero Turn which does a great job and is fun to operate. There is a small dirt road for myself and my neighbors that could use some maintenance from time to time, however it isn't bad and some of the neighbors have equipment and maintain it. I would like to help out. In the back of my mind, and since I am close to retirement, I think about starting a small business with the tractor I end up with. I am also thinking about planting various fruits and perhaps a veggie garden and starting a mini farm with some animals.
I am debating between the 1025R, the 2032R and the 3039R with a deluxe cab. Here are my thoughts, and I would appreciate any input.
1025R is obviously the easiest on the budget. I believe it would accomplish what I need to it to do. Albeit at a slower pace. And I could see myself upgrading if I end up having to do anything beyond light work.
2032R has more weight and HP and very well may be the middle of the road between the 1025R and the 3039R. It would easily handle what I need done.
3039R with a cab (I wouldn't buy an open station 39R, I'd stay with the 2032R for that) would be all of the above and in comfort and style at the same time. Air conditioning and stereo, and I can't see having to upgrade. If anyone has any experience with the 3039R cab version, please chime in as to how the comfort level is, how the stereo sounds, etc. I don't expect it to ride like a Cadillac, of course.
Thanks in advance for any input.
   / 1025R, 2032R, maybe a 3039R. Input please. #2
The comfort level, ride, and how the stereo sounds?....Uhm... sure you’re in the right place?
Personally, it’s the business end(s) that are my priority. Weight, horsepower, emissions, loader capacity, tire type, width (if hilly), number of SCV’s, 3 point hitch type (Class 0, 1, or 2) etc.. To each their own.
Joking aside, I don’t have any of those tractors. There’s a guy on youtube with a 1025r that puts out good videos and reviews. Also has a few 3320 and 3039r videos. Tractor Time with Tim - YouTube
   / 1025R, 2032R, maybe a 3039R. Input please. #3
There is a big difference between the 1 series and the 2 series because of the wheel size difference. The 1 series has limited ground clearance and limited 3 point lift. Be sure to consider whether this will make a difference to you. To me, the 1 series is a lawn tractor with real tractor lift and loader capabilities. That might be all you need but if you already have a zero turn, I would want to go larger with the tractor. The cab issue is obviously a personal issue as to how OK you are with the weather.
   / 1025R, 2032R, maybe a 3039R. Input please. #4
The occasional uses that for what you need a tractor for would point me to the 2032R, especially when it comes to the availability of attachments/implements.
   / 1025R, 2032R, maybe a 3039R. Input please. #5
A Second for the 2032R for two to five acres.
None of these three are robust enough to survive the difficult jobs commercial service bring.
John Deere 2032R
2013 - 2017 2R Series
Compact Utility tractor
Series back: John Deere 2025R
Manufacturer: John Deere
Factory: Augusta, Georgia, USA
Original price (USD)
$18,595 (2013 )
$19,339 (2014 )
John Deere 2032R Engine:
Yanmar 1.6L 3-cyl diesel
John Deere 2032R Power:
Engine (gross): 31.7 hp [23.6 kW]
Engine: 32 hp [23.9 kW]
PTO (claimed): 23.5 hp [17.5 kW]
Capacity:
Fuel: 7.1 gal [26.9 L]
Hydraulic system: 3.9 gal [14.8 L]
Front axle: 0.9 qts [0.9 L]
Transmission: hydrostatic (2-range)
3-Point Hitch:
Rear Type: I
Control: position control
Rear lift (at ends): 1433 lbs [650 kg]
Rear lift (at 24"/610mm): 1250 lbs [567 kg]
Power Take-off (PTO):
Rear PTO: independent
Clutch: wet disc
Rear RPM: 540
Mid PTO: independent
Mid RPM: 2100
Dimensions
Weight (shipping): 1973 lbs [894 kg]
Drawbar capacity: 562 lbs [254 kg]
Front axle load: 1940 lbs [879 kg]
Rear axle load: 2426 lbs [1100 kg]
Wheelbase: 65.2 inches [165 cm]
Length: 108.9 inches [276 cm]
Width: 47.1 inches [119 cm] (min)
55.6 inches [141 cm]
Height (hood): 53.3 inches [135 cm]
Height (ROPS): 89.7 inches [227 cm]
67.5 inches [171 cm] (folded)
Clearance (front axle): 13 inches [33 cm]
John Deere 2032R attachments:
mowing deck
snowblower
blade
front-end loader
backhoe
Mechanical:
Chassis: 4x4 MFWD 4WD
Final drives: spur gear
Differential lock: standard
Steering: power
Brakes: wet disc
Cab: Two-post foldable ROPS.
Hydraulics:
Type: open center
Capacity: 3.9 gal [14.8 L]
Pressure: 2421 psi [166.9 bar]
Mid valves: 2
Pump flow: 5.0 gpm [18.9 lpm]
Total flow: 10.5 gpm [39.7 lpm]
Steering flow: 5.5 gpm [20.8 lpm]
Electrical:
Ground: negative
Charging system: alternator
Charging amps: 40
Charging volts: 12
Battery:
Number: 1
Cold-cranking amps: 500
Volts: 12
Page information:
Last update: September 16, 2016
Copyright: Copyright 2016 TractorData LLC
Contact: Peter@TractorData.com
   / 1025R, 2032R, maybe a 3039R. Input please. #6
Curious as to why you left 2025r off the list. Based on your other picks it would seem that it would fit the list better than the 1025r.
A couple years ago I sold my 3320 (needed boat motors!) and missed it more than I thought I would. Previously I had an older 855 and the 3320 seemed too large for my small place. Last summer I bought a 2025r with a loader, 4in1 bucket, backhoe, and tiller. Could not be happier.
   / 1025R, 2032R, maybe a 3039R. Input please. #7
If you can live without A/C in a factory cab, then 2032R. It's going to handle the peak jobs you may have long term, but it's still light/small enough to go where you need more than the Z-turn for mowing. And FWIW, I have a 2025R Gen 2 and it's a great machine for driveway work and the 120R loader lifts household loads of firewood, etc. nicely and moves all the farm waste, handles digging nicely (added a Heavyhitch toothbar which is awesome for adding utility to the loader). But it's too light for real farm groundwork (unless there's a lot of ballast on the tires / 3 point and even then it won't make ditches without multiple shallow passes). '
None of this addresses the cab factor of course... To get A/C for Florida temps, you're looking at 3039R to get factory A/C on a larger frame machine so no going on the lawn with it unless ground is dry. If the cab is essential, then I'd suggest you look at Kioti's line as they are embracing the small frame cab market more aggressively than Deere and you'd get a good idea how this compares to green. If you have a good dealer close for the long haul service, etc., Kioti makes a good machine and the SE trim line includes a lot of functionality with rear hydraulics, great FEL capacity and comfort features for the operator. I drove Kubota, Deere, Massey, Kioti and the CK3510 SE version with cab is a sweet machine. They now have a smaller 25hp version with AC (CK2510 SE that TTWT did a series on). Kioti durability and global parts supply chain aren't on par with Deere IMHO though, but how long will you REALLY keep a machine is the key question.
   / 1025R, 2032R, maybe a 3039R. Input please. #8
A 2025R would do everything you listed at low cost. And no emission motor with DPF to worry about. I have the same size tractor (although different color) as a 2025R and I do more work on a bigger property than what you listed in your needs. Plus I do snow removal and landscaping jobs for other people on my road.
But if you don't mind spending the money I would buy the smallest model of the 3R with a cab for sure. I personally don't care for the 1 and 2 series JD's, but the 3 and up are really nice tractors. I wanted the previous series to the 3R back in 2013 when I bought, but I would have had to finance. So I went smaller with the cash I had at the time.
But that 3 series Deere would have been sweet too.....cab, still small and light enough to mow with.
   / 1025R, 2032R, maybe a 3039R. Input please. #9
I agree look at a 2025r although a 2032r is quite a bit more tractor. A 2025r is similar to a 1025r but on a bigger chassis with more ground clearance and bigger tires. It all really depends on how much you want to spend.
Case 721B (A47384)
Case 721B (A47384)
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
2013 BMW X5 xDrive50i AWD SUV (A50324)
2013 BMW X5...
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2021 ASV POSI-TRACK RT-120 FORESTRY SKID STEER (A51242)
2021 ASV...
