1085 Massey Ferguson looses prime after 48 hrs. 1979 mod
   / 1085 Massey Ferguson looses prime after 48 hrs. 1979 mod #1
Mike1955
Platinum Member
Kubota
My problem is: I have to prime the injector pump and bleed the injectors after it sits for two or three days. The tank is lower than the rest of the stuff. It's been this way for several years and I just joined this site and thought I would post this and get some ideas. I'm thinking the fuel pump might be leaking down but it would be expensive to guess. All the steel lines look good. I have not changed the filters latelyany ideas, please share
   / 1085 Massey Ferguson looses prime after 48 hrs. 1979 mod #2
For sure put in new filters, but... I'll bet there are rubber/vinyl lines somewhere in the chain. Maybe joints at the filters, etc. They probably have developed cracks over the years and you are very likely getting tiny air leaks into your fuel lines. The symptoms fit.
Thank you JWR. I'll work in that filter area next. To my knowledge I don't see any rubber lines. I wish there was a working valve before the fuel pump. So much trial and error but I'll finally get it. This is an AWSOME old tractor. Tight from front t back air don't work so I just use an electric fan with an inverter. Again thank you
   / 1085 Massey Ferguson looses prime after 48 hrs. 1979 mod #4
You might not find any length of rubber lines but still there may be joints between your steel line and filters, between the steel lines and pumops, & other things. Any of those rubber or synthetic material joints are potential culprits with tiny air leaks.
UNUSED X-STAR 20' X 101" LOADING RAMP (A58375)
UNUSED X-STAR 20'...
2024 Suihe Storage Shelter (A56859)
2024 Suihe Storage...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
New/Unused 14ft Bi-Parting Iron Gate (Cow Design) (A57454)
New/Unused 14ft...
54 Inch Wagon Wheel (A57454)
54 Inch Wagon...
2014 POLAR TANK TRAILER CRUDE TRAILER (A58214)
2014 POLAR TANK...
