10w oil
   / 10w oil #1
Kitz
anywhere usa
IH 244
:confused2:hi everyone. i just got a 1982 ih 244 compact with 2000 hrs on k3d diesel. its dipping into the teens and my owners manual says to use 5w-20 or 5w-30 below 0 degrees. 10w oil below 32 degrees. and 30w above 32 degrees and not to substitute 10w-30 or 10w-40 i cant find 10w and id like to run syn oil. would anyone have any ideas on what i could use that would meet class cd oil and that i could use all winter season. thanks for any input.:confused:
   / 10w oil #3
By coincidence I called Caterpillar Tractor today because my 1975 model requires 30 wt or 10 wt depending on temperature and I was no longer finding it at my regular supplier
I was told I should be using Rotella 15-40 in my mild CA climate year-round
   / 10w oil #4
Your owners manual allows 5w30. You can get diesel rated oils in this multi-grade good for year round service. This is what is used in our VW TDIs, 2009+. I use Mobil 1 0w30 in my 4010. It has a mild diesel rating. I change it before 100 hours vs. rated for up to 200 hours by the manufacturer of the engine. TDIs go 10k miles on synthetic 5w30.
A 5w30 surpasses 10w, etc. requirements. Gives you down to 5w at startup and 30w at operating temperature.
Ralph
   / 10w oil #5
Use Rotella is that's your wish but here is better choice IMO
Synthetic 5W-30 Heavy-Duty Diesel Oil
   / 10w oil #6
I second K7LN's recommendation. I use synthetic 5W-40 in EVERYTHING I own. One oil on shelf. Goes in push mower, riding mowers, pressure washer, generator, 1950 Ford 8N, wifes car, my truck, Kubota, etc. This is a mixed fleet oil for many year round all climate applications, 0F to 95F for me. Philip.
   / 10w oil
well it sounds like im going with rotella. its more accessable. well with 4 quarts 5w-40 syn would it be ok to fill the last quart with 15w-40 non syn. i used that in my mower and have a extra qt plus its twice as costy for a qt. amsoil is 10 dollars a qt here thats real costly but to each his own.
   / 10w oil #8
Can you add 1 quart of 15w-40 to 4 quarts 5w-40, yes. Would I do it, no. Would it hurt anything, no. Doing this dilutes the fine properties of synthetic oil you just used. Philip.
   / 10w oil #9
Go to your wal-mart and grab some T6 Rotella or Mobil 1 TDT both are 5w40's with great pour point specs and WILL perform fine and flow great in them cold temps and protect your engine beautifully.
   / 10w oil #10
Just buy 2 gallons of your rotella of choice. Pour 1 qt out of the second to complete your oil change. Set the other 3 on the shelf for either your mower or adding to that oil burner car you have or like me (i use regular rotella 15-40), i leave it on the shelf and next oil change i will buy a new gallon of rotella and then use anouther qt out of the partial jug. So it will be 4 oil changes till you will need to buy a second gallon again. Like you said a single qt is almost half of what the gallon costs. If buying 2 gallons will break you or cause financial strain you might rethink the whole tractor thing.
Yea i would not mix either. It will not hurt, thats what semi-syn oil is anyway. But you spent money to get the syn, why turn it into a semi-syn oil?
2018 PETERBILT 579 SLEEPER (A51222)
2018 PETERBILT 579...
2021 John Deere S780 Combine (A50657)
2021 John Deere...
2017 Makita HM1307CB 35lb Demolition Hammer (A49461)
2017 Makita...
2020 John Deere 870GP Articulated Motor Grader (A49461)
2020 John Deere...
2022 John Deere 8RX410 Track Tractor (A50657)
2022 John Deere...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
