12' Batwing cutter. Pros and cons of diff. brands.
   / 12' Batwing cutter. Pros and cons of diff. brands. #1
rutwad
Platinum Member
Alabama
Massey Ferguson 5465, Kubota M5040, Farmall H (2), Minneapolis Moline R, Case 530CK, Cat 416C
I see that Landpride, Bush Hog, and Rhino now all make a 12' batwing rotary cutter. Any owners has any special points or dislikes about their brand? Or is this more of a Ford/ Chevy/ Dodge debate. To each his own
   / 12' Batwing cutter. Pros and cons of diff. brands. #2
I never heard if a 12' b/w. I had a Woods 15' that I got at an auction, it was county owned so it definetly saw some use but it didn't show it. It was a fine mower. Like any mower, good (hp) gearboxes, heavy decks and construction in general. I like the laminated tires also.
   / 12' Batwing cutter. Pros and cons of diff. brands. #3
Dealer has lots of 12 foot b-wings on his lot. Bushhog and Rhino are both the same company so I would imagine they have much in common. Early Rhino's 12 foorwea had issues with the hinge on the wings but they corrected that. Landprides stuff I've had and examined has been well made and thought out. Apparently Landpride actually has a engineer that designs their stuff! :rolleyes:
   / 12' Batwing cutter. Pros and cons of diff. brands. #4
I have been looking at 12' batwings for a while. Currently there are only three major players in the 12' batwing world, and nearly everyone makes single fold 10 footer. All three brands are way too light for anything more than clipping short grass. The Bush hog 2212 appears to be very close to the Rhino but is at least $2k more than the Rhino, and the Rhino comes with aircraft tires. The Landpride appears to be the lightest of the three. I have talked to Rhino and Bush Hog about making a heavier 12' batwing but appear to be no interest at the time.
One brand not on the radar is Lowery Manufacturing in Boaz, Alabama. They have started producing a medium duty cutter in both 12 and 15 foot units. I have seen the 15 foot unit up close (actually have pics) and it looks very nice for its price. I was told the 12' is the same build just smaller. Like all LMC stuff it appears to be rough cosmetically but I have several of their attachments and they are all holding up very well.
FWIW the price on their 12' batwing cutter was $6500 at the first of the year.
The Lowery sounds attractive at that price. I did notice the bush hog uses 4" blades vs. 3" for the others. Landpride has the fastest blade tip speed. But the LP recommends 50 minimum HP, while Rhino recommends 35-50.
   / 12' Batwing cutter. Pros and cons of diff. brands. #6
Did you get a 12 foot cutter? I'm still years away from doing this, but think that it's makes the most sense for the money. Less HP needed and you get plenty of width for cutting closer to stuff out past the width of the tractor tires.
Eddie
Eddie, I haven't pulled the trigger yet. I see Woods also makes one along with a 15' for lower HP tractors.
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
2020 KENWORTH W900L DAY CAB (A52472)
2020 KENWORTH...
2019 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2019 PETERBILT 567...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
2009 Ford Escape Hybrid SUV (A50324)
2009 Ford Escape...
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
