12 Volt Electrical / Battery Question
   / 12 Volt Electrical / Battery Question #1
JD 4520
Platinum Member
Snohomish County WA
John Deere 4520
I have a three year old Cummins all house generator. It has a new 12 volt battery within the past two months. Today I went out to test start the generator and discovered that the battery was dead. I jump started it with my truck. It started right away, then I disconnected the jumper cables at which point the generator stopped. I reconnected the jumper cables, started right up, waited approx one minutes and disconnected the jumper cables; the generator stopped again. The third time I reconnected the jumper cables, started the generator, ran it for 3 - 5 minutes, disconnected the jumper cables and this time it continued to run just fine. I now have the maintainer charger on and will leave it on for several days.
Q: Why would the generator stop running as described above just because the battery was low?
   / 12 Volt Electrical / Battery Question #2
Is this a diesel generator?
   / 12 Volt Electrical / Battery Question #4
It is a Natural Gas Generator.
Then it has spark plugs that require electricity. If your generator has a charging system it sounds like this charging system is failing. Both to charge your battery and provide enough electricity to fire the spark plugs.
   / 12 Volt Electrical / Battery Question #5
You could put an ammeter between the battery and charging wire to see how much output is there. Of course, if the engine dies as soon as the battery is disconnected, the unit is not charging.
   / 12 Volt Electrical / Battery Question #6
Gary, your battery was so discharged that it took all the capability of your generator's charging circuits. In other words, the discharged battery was loading down the 12 vDC section of the generator so much that it could not supply the ignition with power. You had to keep your jumper battery attached long enough that the internal battery took on some charge and the current load dropped a bit. If you had completely disconnected the internal battery and only had the jumper battery attached, it would have kept going when you remove the jumper battery because there would have been no load on the charging system.
Also, you obviously have something wrong with the generator that is causing it to drain your starting battery. I would invest in one of those battery terminal mounted disconnect switches to open the battery circuit when not in use. Unless you can find the drain on the battery, you'll keep having this problem over and over. You may have a leaky diode or partial short in the circuit that is allowing the battery to slowly drain over time.
   / 12 Volt Electrical / Battery Question #7
.......... You may have a leaky diode or partial short in the circuit that is allowing the battery to slowly drain over time.
Or the generator is not charging the battery. Again, an ammeter between the battery and the charging wire will show charging rate and discharge rate, due to a leak or short.
   / 12 Volt Electrical / Battery Question #8
An ammeter is a bit of a pain to install without an inductive pickup. A simple voltmeter reading will tell if the generator is putting out enough to charge the battery. Since he said it maintained after keeping the jumper battery in place for a few minutes, I'd bet the battery is being charged. Remember if his battery is dead, it will be a huge load on the charging circuits. Their response is to drop the voltage to limit current. After the generator will run by itself, I'd let it run for 10 or 15 minutes and check the voltage across the battery leads for greater than 12 volts. When the battery is fully charged, the voltage should read 13.85 to 14 volts with the generator running and around 12.5 volts after the generator is shut down. As with automobiles, voltage monitoring of the charging system is far more common than current monitoring in modern instrumentation. There's nothing wrong with what you are suggesting except it's just more difficult in my opinion.
Edit: Your suggestion of checking leakage current with an ammeter is a good one. Most ammeters have low current capability and would show the drain. I would not use the same ammeter for looking for a small drain as I would to monitor charging current.
   / 12 Volt Electrical / Battery Question #9
My generator's electronics will kill the little battery (Kohler-powered propane 10KW) in a few weeks unless the generator is run. There is a little 'computer' but since it uses LED numerical readings, I knew from the start it wouldn't be as efficient as one using LCDs.
I added a second little battery, doubling the reserve, and put a 60 watt solar panel on it and haven't had a problem since.
As the OP mentioned, a battery maintainer would be a good idea (like the little Battery Tender). I'd just leave it connected rather than connecting it for a few weeks on and off.
Phil
   / 12 Volt Electrical / Battery Question #10
A...........I would not use the same ammeter for looking for a small drain as I would to monitor charging current.
Right. I have an automotive ammeter gauge that reads +/- 30 amps with alligator clips, so I can plumb it in easily to check charge rate. For reading the drain current, I'd use a little multimeter, in milliamps.
   / 12 Volt Electrical / Battery Question #11
Two suggestions -
I would charge the battery and then take it to a auto shop and have it tested under load. It may have failed. It happens on even new batteries.
You say that you manually test start the generator. In another thread it was advised that generators sometimes will lose their magnetism it they are run without load. I have a small light bulb and ac socket to lamp socket adapter that I plug in to the generator while I'm test running it for fifteen minutes once a month.
Thanks so much for the input on this matter. All very helpful. I will test run it weekly during the winter and check outputs. The current alternator output is 14.25 v so that is working fine. Since it is connected to my house I will need to activate it under load as well as just running it.
Have a great rest of the week.
   / 12 Volt Electrical / Battery Question #13
new generators use electronics to keep on all the time. they will drain a good battery pretty quick. not to mention that batteries will drop regularly about .1 volt per week without charging.
mark
2025 GPS Equipment Trailer (A56859)
2025 GPS Equipment...
UNUSED SDLANCH SDLC2030FT-20'X30' CARPORT (A60432)
UNUSED SDLANCH...
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
2015 Ford F-250 Service Truck w/ Liftgate (A59230)
2015 Ford F-250...
UNUSED ZJG ZJ-08 MINI DIGGER (A60430)
UNUSED ZJG ZJ-08...
2001 CATERPILLAR CB-634C SMOOTH DBL DRUM ROLLER (A60429)
2001 CATERPILLAR...
