135 hydraulic linkage
   / 135 hydraulic linkage #1
hd5
Missouri
MF2705, MF135 XR4046H
My 135 has quit lifting a heavy load. It will pick the arms all the way up empy, but with a bale of hay it rises very slowly and only about a foot.
If I remove the inspection plate on the right and move the position lever upward the vertical lever will only move the pump lever (the one with the roller) a short distance. If I use my finger I can move the lever toward the rear of the tractor and it raises quickly and smoothly. I am not able to see if it will do that under a load though.
Also if I move the positon lever to constant pumping it does not cause the relief valve to pop, I think it used to.
If I manually move the pump lever the relief valve pops.
It seems I am out of adjustment , I assume the lift cover needs to come off, I have done it before, don't like it.......
What do I need to adjust?
TEST YOUR BID BUTTON! (A51246)
TEST YOUR BID...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
UNUSED FUTURE FT36CJ STAND ON SKID STEER (A51247)
UNUSED FUTURE...
UNUSED HURRICANE 20' X 20' ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2016 FREIGHTLINER...
