135 MASSEY FERGUSON AG3-152 Oil Leaks
   / 135 MASSEY FERGUSON AG3-152 Oil Leaks #1
stanmcleod
135 Massey Ferguson
Have change the rear seal on the crankshaft several times and I still have the tractor leak oil at the cotter pin behind the oil pan.
Need some expert help on correcting this sisuation Has anyone had this problem
and how do I correct?
Have done this several times have replace all the gaskets that are require for this operation , like the gasket inbetween the oil seal housing and the rear oil seal also the oil pan gaskets. Is there a way to find out the correct seal for the housing?
   / 135 MASSEY FERGUSON AG3-152 Oil Leaks #2
I have went through what you have done a few time myself with about a 50-50 chance of success. This seems to be related to the main bearings being loose and ruining each new seal as soon as it is put in. Short of a major rebuild on the engine lower end, Put some Lucas in and drive on. I think you are fighting a losing battle. Ken Sweet
   / 135 MASSEY FERGUSON AG3-152 Oil Leaks #3
Yup, bearing roll.
That or it's the transmission leaking and you're fixing the wrong problem.
   / 135 MASSEY FERGUSON AG3-152 Oil Leaks #4
Change your oil pan gasket. I ran into the same problem and it was the oil pan leaking threw into the weep hole. Tore it down 3 times before someone told me about that and it hasnt leaked since.
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
JCB 507-42 Telehandler (A51573)
JCB 507-42...
2017 Chevrolet Malibu 1LT Sedan (A51694)
2017 Chevrolet...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
