14T baler
   / 14T baler #1
James fulton
georgetown, KY
JD 5105
I am looking at a JD 14T baler. It is in good shape and is baling but the left knotter frame is cracked. Is this knotter frame interchangeable with any others from JD?
   / 14T baler #2
The parts site shows they used 3 different ones,depends on serial #,the last one for 47540 and up,is the same as a 24T. Do you know what the serial # is?
   / 14T baler
The # is 181407. What I am wondering about is the casting that holds all of the guts for the knotter. It is cracked by the twine disk. I can get it welded if needed but would rather replace it.
Thanks.
   / 14T baler #4
i have a 14t bailer with i believe to be the old style knotters. everything works great but the left side facing the tractors knots tail is a bit to short. and sometimes slips the knot which as you all know is a real pain. how do i adjust the tail length?
   / 14T baler #5
I would have a "very" experienced/certified welder nickel rod weld the knotter casting together. This will be extra easy if there are no casting chunks missing. Don't have the casting brazed... probably won't hold long.
I had a cracked knotter on my 24T I was bringing back to life. When I saw the new & ebay prices of these, welding it was my only option. I found a chunk of the casting that had broken off which made the job only $30!!
1998 VOLVO A40 OFFROAD DUMP TRUCK (A51242)
1998 VOLVO A40...
2017 Jaguar F-Pace SUV (A50324)
2017 Jaguar F-Pace...
WEATHERFORD TRIPLEX PUMP WITH ELECTRICAL PANELS (A50854)
WEATHERFORD...
2006-2009 Ford 4x4 Pickup Truck Bed (A49461)
2006-2009 Ford 4x4...
1996 Lincoln Town Car Sedan (A50324)
1996 Lincoln Town...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
