1510 transmission/hydraulic
   / 1510 transmission/hydraulic #1
mythnmagic
UK,SUFFOLK
Yanmar Ym1510
Thanks for your help :)
   / 1510 transmission/hydraulic #4
Yep, that's the one. Check the Product Profile, (JD303).
   / 1510 transmission/hydraulic #5
The spec that we often quote and what these tractors should take is the JD303 spec. But as was brought up in anot her recent thread, what does that (jd303) spec really mean, as it is an obsolete 50 year old spec that you can't actually legally make since it contained whale oil. Now you can say exceeds it I guess but again no one tests that it does meet that.
But honestly about any tractor/transmission universal fluid that you can buy now a days which calls itself 303 fluid will be fine. Pretty much any modern tractor fluid will be more than sufficient, whether it be JD Hy Gaurd or kubota UDT or whatever then brand it will be fine.
   / 1510 transmission/hydraulic #6
Automatic transmission fluid also will work fine in these tractors....I have used it in my 186D before.
   / 1510 transmission/hydraulic #7
You are correct. But for the simple geared transmission, not the power shift I personally unless I was in extreme cold would not consider that, since I can buy a 5 gallon bucket of tractor transmission fluid for $20-30.
But you are correct you certainly can use ATF.
   / 1510 transmission/hydraulic #8
Yea...it's an option if you have trouble getting the tractor fluid...best to go with the tractor fluid.
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
2000 Genie S-60 60ft Telescoping Boom Lift (A50322)
2000 Genie S-60...
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,400lb 3 Ton Crane Service Truck (A50323)
2014 Ford F-550...
Rears 500 Gallon Orchard Sprayer (A50121)
Rears 500 Gallon...
2012 WESTERN STAR 4900 SB (A52472)
2012 WESTERN STAR...
2011 Cadillac DTS Sedan (A50324)
2011 Cadillac DTS...
