1520 neutral adjustment??
   / 1520 neutral adjustment?? #1
Kays Supply
Veteran Member
Southern Illinois
Iseki TA 207
Does anyone know if there is a way to adjust the neutral position on the foot pedal? I have a friend that has a 1520 that is either in forward or reverse. There doesn't seem to be a neutral on the foot pedal. He said it had a wider neutral space before. The exposed linkage doesn't help.
   / 1520 neutral adjustment?? #2
The I&T manual has a paragraph on this adjustment:
Remove center panel from rear of steering column shroud. Adjust length of rod between foot pedal and pivot linkage to 129.5mm/5.1 inches. Adjust length of rod between pivot linkage and hydrostatic unit to 137mm/5.4 inches. Start engine and shift trans to low range. Adjust neutral rod spring tension nut to provide sufficient tension to return foot pedal to neutral position when released. Stop the engine and move the foot pedal to fully depressed position. Adjust length of pedal stop bolt to just contact step plate, then lengthen it two more turns.
There is picture that goes with this showing the linkage and numbering the parts for reference. If you need a scan of this page, just shoot me a PM.
Ed
Thanks a bunch for the info. We have done the adjustments described. The problem is that there isn't any neutral to adjust to. It is either in forward or reverse. I guess he will have to fall back and punt, take it to a dealer.
2017 International DuraStar 4300 26FT Box Truck (A51692)
2017 International...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2012 WESTERN STAR 4900 (A53843)
2012 WESTERN STAR...
2016 CATERPILLAR 325FL EXCAVATOR (A51246)
2016 CATERPILLAR...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
