1528 hydro pedal sticking
   / 1528 hydro pedal sticking #1
double e
southern maryland
massey ferguson 1528
I did do a quick search but did not find anything. I was wandering if anyone else has had this problem. When I let off the pedal the tractor keeps going foward as the pedal slowly returns back to position, I find this very dangerous or at least destructive when doing close proximity work. I tryed greasing the fitting but no help. I used the same grease as I use on all other fittings, but was thinking maybe that grease is to thick/ tackey for this application. Any thoughts or suggestions would be great, Thanks
   / 1528 hydro pedal sticking #2
Mine is doing the same thing on a 1526. I haven't had time to look at it real close but I also had a 1215 that did it the same thing. There is a little roller on top of the transmission I sprayed some wd40 on it and it started working good after that. Ill see if I can't find a picture of it tomorrow. I don't know how your tractor floor is but the 1215 had a cover right in the middle. Four bolts and I could access it.
2013 HINO 338 26FT BOX TRUCK (A58018)
2013 HINO 338 26FT...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
2000 INTERNATIONAL 4900 CAR HAULER (A58018)
2000 INTERNATIONAL...
2011 WABASH 53 FT DRY VAN (A58018)
2011 WABASH 53 FT...
2023 Polaris Ranger SP 4x4 Utility Cart (A55787)
2023 Polaris...
2018 CATERPILLAR 299D2 SKID STEER (A52709)
2018 CATERPILLAR...
