1533/1540 12x12 powershuttle ground speed table
   / 1533/1540 12x12 powershuttle ground speed table #1
timo
se michigan
Does anybody know the ground speeds for the powershuttle trans at PTO rpm with Ags? It seems like something that would be in the MF literature but I can't find.
thanks!
tim
   / 1533/1540 12x12 powershuttle ground speed table #2
Hmmm I wonder why it isn't in the book. If you can see the tractors in person it should show that info on the fender. Not sure what tire they use for the info. Also I would think the 33 and 40 will be the same speed.
   / 1533/1540 12x12 powershuttle ground speed table #3
Your local dealer can give you that information.
   / 1533/1540 12x12 powershuttle ground speed table #4
If it hasn't been changed, it should be right around 17 mph or slightly above.
   / 1533/1540 12x12 powershuttle ground speed table #5
</font><font color="blue" class="small">( If it hasn't been changed, it should be right around 17 mph or slightly above. )</font>
I guess the top gear is the same on most? Just saying that because that is my top speed on my 8x8.
   / 1533/1540 12x12 powershuttle ground speed table #6
They have always been pretty consistent with the top speeds. The lower gears have changed according the type of transmission and if it has creeper gears or not.
Actually, I'm more concerned about the lowest (creeper) speed. I like to know as much as possible before talking to any dealers.....
tim
New/Unused 20 Ton Hydraulic Jack (A57454)
New/Unused 20 Ton...
2001 Kubota KX61-2 (A55272)
2001 Kubota KX61-2...
LOT: (80 approx.) Gallons of Chevron Delo 400 XLE SB SAE 15W-40 Synblend (A59076)
LOT: (80 approx.)...
2012 DOOSAN G25 GENERATOR (A58216)
2012 DOOSAN G25...
PALLET OF PORTABLE AC UNITS WINDOW AC UNITS & MORE (A58376)
PALLET OF PORTABLE...
Jumper Cables (A57149)
