1533 4 wheel drive will not engage
   / 1533 4 wheel drive will not engage #1
Sap Masta
Guilford, Maine
Massey Ferguson 1533
I have a Massey 1533 with 235 hrs. I took it out of 4 wheel drive a while back and now it doesn't seem to want to go back in. I have had everything in neutral - no go... clutch depressed as well... Then I tried "feathering" it in with a little while releasing the clutch slowly in low gear. No go.
Any thoughts?
   / 1533 4 wheel drive will not engage #2
Does the shift lever travel through its range of motion? It's a fairly straight forward shift mechanism. If it's bound, it could be the sliding gear on the shaft or a bound mechanism. The lever rotates and transmits via a link to a shaft on a shift fork. The shift fork slides a gear on the front driving shaft.
Thanks very much - I got it - operator error involved!!
   / 1533 4 wheel drive will not engage #4
I have an MF1529 and it recently quit going into four wheel drive. I finally looked underneath the front assembly and found the front drive shaft cover tube. I slid the tube back and found a 3 inch splined coupler that had backed away from the front spindle. It is held in by a snap ring that had slipped causing the coupler to disengage the spindle from the drive shaft. I reinserted the coupler and snap ring and it works fine now.
UNUSED FUTURE PR71 71" HYD POWER RAKE (A58376)
UNUSED FUTURE PR71...
2013 Gillig G30B102N4 Transit Passenger Bus (A56858)
2013 Gillig...
2003 Big Tex 10PI...
New/Unused Electric 3-Wheeler (A57453)
New/Unused...
2008  BIG TEX 16' T/A TRASH TRAILER (A58216)
2008 BIG TEX 16'...
UNUSED 250 GALLON FUEL TANK (A58375)
UNUSED 250 GALLON...
