1538 rear axle won't stay locked
   / 1538 rear axle won't stay locked #1
LowellBen
2015 Mahindra 1538HST
I haven't done any searching of the forums - my bad.
I can't keep the rear axle locked. Even with my heel on the lever, it kicks out. Am hoping that the gear or whatever is just not engaged all the way. I guess the worst case is that the PO did something to damage things.
I was wondering if anyone knew if there is an adjustment to the linkage. I can't see where the linkage goes without taking the seat and maybe the seat pedestal off. I don't want to waste my time taking things apart if there is no adjustment.
I'm working on a slope of about 25 degrees and it sure would be nice to have three wheel drive instead of just two. I'm cutting in a trail on some pretty steep and rocky hills. I first loosen things up with the hoe and then turn the tractor around and smooth out the loosened stuff with the bucket. Tedious.
Tractor has 225 hours on it now. I bought it used as a repo with just 110 hours on the meter.
Thanks,
Lowell
I talked to a shop about this. There is an adjustment on the right side near the axle tube. I took a pretty big swing at it and ended up with a condition where the actuator arm bottoms out internally just as the linkage hits a travel limit stop. I can now engage diff lock and it doesn't want to kick out during sharp turns and I'm dragging one of the rear tires. The test will be when I get it up on the slope and the drivetrain loads up. When I use my heel to disengage the diff lock and then move the tractor, I can hear a click when the lock disengages.
Lowell
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
Year: 2014 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 220551 Plate: Body Type: Cutaway (A51692)
Year: 2014 Make...
2014 Nissan Pathfinder SUV (A53117)
2014 Nissan...
Travel Trailer (A51694)
Travel Trailer...
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
JOHN DEERE 9650 COMBINE (A51247)
JOHN DEERE 9650...
