1547 hst doesn't want to return to neutral
   / 1547 hst doesn't want to return to neutral #1
donais
ramona ca
mf 1547
when i push the pedal to forward and reverse the tractor will not return to neutral unless i pull the pedal up. i removed the damper to test the return. it got a little better but not much. forward is much worse then reverse. i also lubed the linkage to no avail... anyone have any ideas? i was reading the repair book and all the linkages are spot on. next stop i think is pressure tests???jon
   / 1547 hst doesn't want to return to neutral #2
My 1648 does this a bit too ... it "creeps" a bit, and I just tap the opposite pedal to close the valve. Doesn't happen every time but it does happen.
I haven't really inspected it for a fix ... but I do try to keep it clean & lubed.
Sounds like yours is worse than mine.
   / 1547 hst doesn't want to return to neutral #3
DOING THE SAME WITH MY 1643 , USUALLY WHEN COLD. When it is running for some time, it is going back to neutral like it should.
Mine has done the creeping forever just tap other pedal. Now it is real hard to pu
Push that is it will run away and not let up
17101 (A55787)
17101 (A55787)
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56435)
2020 Westfield MKX...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
2023 Caliber Trailers GH840MST 40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
2023 Caliber...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
