1630 dual clutch replacement
   / 1630 dual clutch replacement #1
dvanhorn81
Dryden, Mi
New Holland 1630
I am new to this forum. I have a question about replacing a dual stage clutch in a 1630 with a 9 x 3 transmission. First time doing this work.
I purchased the repair manual, and have torn down the tractor and split the unit to access the clutch. It says in the book to adjust the clutch finger height. I have spoken to the dealership, and ask them about the setting guage. They said to just look up the measurement and adjust with out the tool. Does anyone know what the height should be??
Can't seem to locate the dimension from the flywheel to the adjusting bolt. Any help would be appreciated/
   / 1630 dual clutch replacement #2
This is the adjustment specs for the dual clutch in my 1900. I do not know if yours is the same.
Thanks, This is more information than the book I have shows. I was going to measure everything before I took it apart, and then try and compensate for difference between the used and new clutch plate thickness
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
JLG 20MVL MANLIFT (A58216)
JLG 20MVL MANLIFT...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
30" X 20" X 72" METAL SHELF (A52708)
30" X 20" X 72"...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
2011 Chevrolet Cruze Sedan (A56859)
2011 Chevrolet...
