1652 auxiliary power for third function solenoid?
   / 1652 auxiliary power for third function solenoid? #1
shawnb2
Greenville, SC
Massey 1652
Hi, I have a 1652 with DynaQPS and cab. The manual says there is an "auxiliary power for third function solenoid" connector on the wiring harness that pulls power from fuse #9 in the main panel. Has anyone located this connector?
I looked under the tractor around the loader valve and couldn't find any unused connectors in the area in front of the right rear tire. I'm wondering if it may be inside the cab, behind the plastic trim under the loader joystick... I couldn't get the bottom panel off, looks like I have to remove the whole top panel first, but I ran out of daylight.
I installed a WR Long valve, and ended up running some extra wire and hooking the in-line fuse directly to the battery; but would prefer to find one of the factory aux power connectors so the power is off when the key is off. FWIW, I'm not impressed with the printed service manual I ordered for this project... :D
Thanks,
Shawn
   / 1652 auxiliary power for third function solenoid? #2
I can't offer any help but I'm interested to see what you discover so I can put it to use on my Massey 1652
JOHN DEERE 9650 COMBINE (A51247)
JOHN DEERE 9650...
BUYER'S PREMIUM INFO LOT NUMBER 2 (A53084)
BUYER'S PREMIUM...
2023 Kubota KX057-5 Compact Excavator (A55315)
2023 Kubota...
2018 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A52707)
2018 CATERPILLAR...
300 GALLON PULL BEHIND SPRAYER TANK (A57192)
300 GALLON PULL...
(5) 12" X 22# X 171.25" (3) 12" X 22# X189" I BEAM (A57192)
(5) 12" X 22# X...
