16LA Hydraulic Control Valve Parts
   / 16LA Hydraulic Control Valve Parts #1
Korishan
Gainesville, Fl
TC40D
Hi,
I'm new to the posting scene on TBN. I've done lots of reading on the site and get loads of information from here.
I have a TC40D with a 16LA loader. The control valve is very lose and upon inspection, I found that the connector rod is very worn out where the stick connects to the valve assembly. I was wondering if anyone knew where to get replacement parts for these that doesn't cost $30+ each. On Messicks, it's $33 each for the lift/lower connectors (part 86400431) and $46 for the bucket actuator (part 86400430).
Thanks for your help
Kori
   / 16LA Hydraulic Control Valve Parts #2
It would be nice to locate parts that cost less .... but, usually when the parts begin with "tractor" or "boat", the price goes up :mad:
Yes, but perhaps someone may know of a metal shop or something of the like that can make these parts much cheaper than the manufacturers of the tractors or boats. *hopes*
   / 16LA Hydraulic Control Valve Parts #4
That would be nice. I hope so too.
Your problem sounds just like the problem I have with my TC40D loader
   / 16LA Hydraulic Control Valve Parts #5
What I have found with all the machining required it is more expensive to have them custom made. I use that as a last resort when parts are no longer available from the manufacturer. Using the old part for a template makes measurements a little difficult, especially with small parts. Best bet is to get the original parts. Keep everything lubricated and they should last another 10-15 years.
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2005 GENIE Z-34/22 ELECTRIC TELESCOPIC MANLIFT (A51246)
2005 GENIE Z-34/22...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
3/8 '' Wolverine Universal Quick Attach Cut Out Mount Plate (A51573)
3/8 '' Wolverine...
