there should be and L shaped rod pin in your clutch pedal you remove it and tighten it up on the other end an reconnect when done u should have 1.5 inches in free travel
I found the L shaped rod . The flat piece of metal it is connected too has two holes in it . The rod was connected too the back hole I put it in the front hole and now it seems to hook up fine. Is this alright?
The clutch engaged at the top. When going up a step grade tractor would lose momentum with motor at steady rpm.Sence moving the rod too the second hole the clutch seems to be alright. Just wanting someone to tell me I did the right thing.
