1720 hydraulic leak
   / 1720 hydraulic leak #1
rambler
Veteran Member
MN
Ford 960, 7700, TW20, 1720; IHC H, 300; Ollie S77
I have a NH 1720 I bought used from the dealer. I had a set of rear remotes installed. It has a 7308 loader on it with joystick control. Owned it for a bit over a year, 250 hours or so I put on it, 700 total.
When I operate the rear remote, it has developed a sudden leak. It leaks on the black nut/stud on the loader hydraulic joystick controler. This is the little (hollow) stud under the rubber boot & metal sheld - where the joystick controls are. I believe this to be the pressure control for the loader? I have not tampered with this, nor does it look tampered with by previous owners.
Anyhow, oil drips out the hollow center when I max out the rear remote lever. It does not appear to do so, or as much, when I operate the loader controls themselves. It does not leak at all when the I'm not operating any hysraulics.
(However, we are in a tornado warning & it got real dark, so I had to park in the shed - need to check more/ better tomorrow.)
Any ideas what is causing this drip?
--->Paul
   / 1720 hydraulic leak #2
I have a 1925 with 7308, yes this is the pressure relief valve. Mine leaked and I changed o-rings on it and it fixed the problem with mine.
I also used Spencers gauge (see other thread) and reset my pressure after doing it.
John Deere 6120E (A50323)
John Deere 6120E...
2022 JOHN DEERE 331G LOT NUMBER 99 (A53084)
2022 JOHN DEERE...
6000 GAL FUEL SKID (A52472)
6000 GAL FUEL SKID...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
Sims Snow Board (A51573)
Sims Snow Board...
2017 VOLVO VNL SLEEPER (A52577)
2017 VOLVO VNL...
