1720 oil capacity
   / 1720 oil capacity #1
gravismaximus
central square, NY
n/a
Looking to change my oils. Bought a manual but it dont have capacity amounts in it. How much oil should i get. Also want to change the hydralic fliuds. Book says use Fnh 134. What is it really? Normal hydraluc fluid?
   / 1720 oil capacity #2
The specifications are at the back of the O&M manual. Mine was pg 55, but my tractor was a 1988 1720. It said,
Rear Axle and Transmision 28.5 qts (~ = 7.13 gal)
Power Steering 1.9 qts
Front Axle Differential Case and Final (outer drive) Reduction 5.3 qts
New fluids often are multiviscosity, like 10w-30. For a tractor such as this, I like the TSC Universal Tractor Hydraulic fluid, which sometimes in the 5 gal size goes on sale, and it is multi-vis.
Don't forget the filters and note that there are multiple drain points on both the rear, tranny and front axle/final drive.
Giyi 72" Grapple Bucket (A57149)
Giyi 72" Grapple...
Mini Skid-Steer Hydraulic Side Shifting Forks (New/Unused) (A59225)
Mini Skid-Steer...
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58216)
2014 TIELKE...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
22in Frost Bucket (A59213)
22in Frost Bucket...
