1735M Speedometer Change from Kmh to Mph
   / 1735M Speedometer Change from Kmh to Mph #1
MF1735Guy
Gainesville, FL
Massey Ferguson 1735M HST
Hey all, I didn't know that the speedometer on a lot of the new Massey Fergusons come stock with the dash reading out speed in Kmh. So I asked the dealership to change it and they came out and did it the same day. I watched him do it and it's super easy to do. I made a 3 minute video showing how it's done. Hope it helps anyone who wants to do it themselves. Thanks!
Massey Ferguson 1700M Series Change Speedometer from KMH to MPH - YouTube
   / 1735M Speedometer Change from Kmh to Mph #2
Huuum I wonder if this will work on my 1736?
It might work fine. You can at least do the fuse part and see if the menu comes up. I'd imagine if it did then it probably works a similar way.
   / 1735M Speedometer Change from Kmh to Mph #4
I just might get brave enough to give it a try, is there anything that you could mess up?
Potentially yes. There's settings for tires and other things in that menu. Just be sure to look for "units". I'd stay away from other settings.
   / 1735M Speedometer Change from Kmh to Mph #6
ok, thanks
Let me know if it works for you and I'll update the description of the YouTube video to say that it will. Thanks
   / 1735M Speedometer Change from Kmh to Mph #8
I've been traveling and just had a chance to give this a try.
It worked!
Thanks so much for posting the video, so much easier to understand when you can see it on a video.
It worked!
Awesome news! Glad it worked for you. Added the info to the video.
   / 1735M Speedometer Change from Kmh to Mph #10
Great video however didn't work for my 1755M. It does show on display screen after removing fuse to change KMH to MPH but no speedometer shows up. Mine is a Power Shuttle open station and was told speedometer only available on HST. Any other Power Shuttle 1700m series owners not have a speedometer? Thanks.
5ft.Brush Chief 3pt. Mower (A46502)
5ft.Brush Chief...
APEX Ag Equipment Hyperdisc H18/20 | High-Performance Tillage Disc for Precision Farming (A48561)
APEX Ag Equipment...
KC High Capacity 101in. Skid Steer Bucket (A46502)
KC High Capacity...
Kivel 3500 Lb Pallet Forks (A47307)
Kivel 3500 Lb...
2086 (A49339)
2086 (A49339)
Miscellaneous Railroad Ties Bridge Planks (A49339)
Miscellaneous...
