1736 Speedometer
   / 1736 Speedometer #1
Ffterman
Ferris, Tx
Massey Ferguson 1736HST
Does anybody know how to change the speedometer from KPH to MPH on a MF 1736HST? I couldn't find anything in the owners manual about it. I called the dealer and was told to hold the button down for 3 seconds, that didn't work. The digital display still reads kph.
I wanted to check with you guys first before I called the dealer back.
   / 1736 Speedometer #2
I just changed my MF1736HST. The service manual is a real joy to try and understand.
1) Make sure the ignition key switch is not turned on. Wait for at least 1 minute before proceeding if the
key switch has been on.
2) Pull out the bottom right hand side fuse (5A) (Mine was orange) on the main fuse box (under the dash
next to the floor with a black cover).
3) Insert the key and turn the ignition key switch on, but do not start
4) The display will go into check mode and then you'll hear the buzzer and "Engine Set" should be displayed
5) Momentarily press the "Display Select Switch" It's the lower of the 2 switches to the left of the steering column
The display should cycle between "Engine" "Class" "Tyre" "Unit" "Sensor" Memory" "Error" and "Clear"
6) Stop when you get to "Unit" and long press the "Display Select Switch" for 2 seconds and it will enter the "Unit Set"
(speed) mode.
7) The display should read "nPH" at the top and "Chang" at the bottom
8) Long press the "Display Select switch" for 2 seconds until you hear the Buzzer go off and release
9) After about 2 seconds the Display should go back to "Unit Set"
10) Turn the ignition switch off and re-install the fuse.
11) Turn the ignition switch back on and the the display should read "mph"
   / 1736 Speedometer #4
I think it does. The service manual I have covers all the models from 1736 to 1759.
push mower (A55973)
push mower (A55973)
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
Trellborg 520/85R46 Tire (A56469)
Trellborg...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A52707)
2017 CASE IH 580...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
