175 lift cover adjustments without MFN -970 tool/gauge
   / 175 lift cover adjustments without MFN -970 tool/gauge #1
EdinOR
Oregon
69 Massey 175, 51 JD B, 48 JD H, 48ish York Turn O Bout
Hello,
So with this tool pretty much impossible to find, what is a work-around? I've searched and searched but have yet to come across a common method used today. From pics that I've seen it looks like maybe it is an extension of the beveled section where the ram arm meets the rear of the lift cover. If that's the case it would be easy to make something work. Anybody know if this is the case or not? Ideas/suggestions? Thanks.
   / 175 lift cover adjustments without MFN -970 tool/gauge #2
Hi Ed, I'm hoping to see some info from someone who has used these tools - otherwise we are all in trouble. I have never done any of these adjustments but I'd like to learn how to set up the hydraulic plate and links/levers correctly so I can when I need to, also to help others and to preserve this knowledge.
This thread may be worth a read - you might understand it better having a tractor apart that you can look at:
https://www.tractorforum.com/threads/165-special-tooling.30911/
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
UNUSED NORTHERN UTV-50 AG MIST SPRAYER (A51247)
UNUSED NORTHERN...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
UNUSED FUTURE FT-HJ6 HD STORAGE SHELVES (A51248)
UNUSED FUTURE...
21000 (A51694)
21000 (A51694)
UNUSED LANHERO LDH-T460 STAND ON SKID STEER (A51247)
UNUSED LANHERO...
