1862 lift valve leak
   / 1862 lift valve leak #1
maineline
endicott ny
cub cadet 1862
I broke down due to lift valve bottom seal failure when mowing. this is the o ring for power steering aux tube. I removed the valve cleaned and replaced o rings on shaft and all o rings for the (4) tubes connecting them to the correct locations and inspected double flair lines for damage and reinstalled and changed fluid and filter which was about due. startup and leaks streams out of same bottom seal. removed and inspected, no reason for leak, it almost seems like there is not enough squeeze on o ring seat. o rings are not pinched or broken have tried several times with same result. can anyone help my lawn is a field now.
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
2011 Nissan Maxima Sedan (A53424)
2011 Nissan Maxima...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
Rooster Weathervane (A55853)
Rooster...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
Liebherr L542 Articulated Wheel Loader (A55851)
Liebherr L542...
