robbycranker
Ok let me start by saying a month ago the thing ran like a champ ,now it cant get out of its own way heres the symptoms
1 the throttle controls no longer control the throttle
2 the carb is wide open and it still barely moves under its own power
3 when u move the throttle lever it moves on governor but it does nothing the the rod that goes to the carb but i can manually move the rod at the carb so the carbs not jammed the butterfly moves freely
things i have done to try to remedy
1 have removed the governor and visually inspected it all parts seem to be fine rods not frozen thrush bearings good spring seems fine the weights are intacked and seem to be functioning and it was all well lubed
2 removed the carb cleaned everything again no obvious issues
3 i checked the timing at number 1 tdc and at the distributor rotor and it seems to be right (side note i cant find the timing mark on the main pully does anyone where this might be located that would be helpful on my other tractor its where the radiator hose is on this one)
4 i dont have a battery on that one i hand crank it and it fires right up so i dont think its to serious but im stumped im not new to farmall ownership usually figure out whats wrong pretty fast pretty simple machines thats kinda why i love them but this ones got me scratchin my head so if anyones got any suggestions im listening and thanks in advance
