1900 verses TC30
   / 1900 verses TC30 #1
Hooked_on_HP
Veteran Member
Coal City IL
Ford 1900 FWD Kubota F2100E
I would like to get a newer tractor with a little more power than my 1900. There is a TC30 for sale localy. After going on tractor data and checking the specs the TC30 has less pto hp than my 1900. This doesn't seem correct since the TC30 has more cubes. Did the change the way they are rated like they did the cars in the 70's.
Bill
   / 1900 verses TC30 #2
nope.. a hp is still a hp.
cubes don't define hp.
using your logic, a ford 9n with 119 ci should have more hp than the tc30 with 91.. right? ? WRONG :)
displacement is only part of the equation. compression ratio is another part of it... then you add in things like natural aspiration or turbo chargers.. etc. which by the way, artificially skew the CI numbers when doing the comparison to a NA machine.. etc.
soundguy
   / 1900 verses TC30 #3
Bill
Take another look at tractor data, and you will see your 1900 even out weighs the TC30. You have more traction, and more PTO HP.
   / 1900 verses TC30 #4
I always considered the TC29 and 30 to be more on par with the Ford 17xx series tractor.
   / 1900 verses TC30
Well, I guess the TC30 is out. For curiosity I am going to see if anyone close has a pto dyno, and if not to expensive, see what my 1900 is putting out. Do most tractors put out what they are rated?
Bill
   / 1900 verses TC30 #7
I've seen some put out more.. depends on the condtion of the engine mostly..
soundguy
   / 1900 verses TC30 #8
I knw for our dyno which is rated to 400 horsepower it doesn't do well with reading at all on the smaller compacts athough we do use it for simulating loads it is not accurate at all for horsepower.
2020 JOHN DEERE 7R210 LOT NUMBER 47 (A53084)
2020 JOHN DEERE...
INOP/NON-RUNNING Hyster Forklift (A51573)
INOP/NON-RUNNING...
2014 Ford Taurus SE Sedan (A51694)
2014 Ford Taurus...
2022 Case IH Magnum 340 AFS MFWD Tractor (A53342)
2022 Case IH...
Ford F250 Pickup Truck (A51694)
Ford F250 Pickup...
2004 Ford Taurus SE Sedan (A51694)
2004 Ford Taurus...
