1910 Rocker Arm Shims
   / 1910 Rocker Arm Shims #1
mike48130
Platinum Member
Plymouth, MI
JD 4410, 4210 Ford 1700, 550, Bobcat 843
Does anyone know how to setup the rocker arms on a 1910? They have 3 individual rocker arms, and not the one shaft for all 3 like most other engines. I have the IT manual, and it mentions that they have 3, but says nothing about how to set up the shims. I suspect, that the rocker arm should be 90deg to the valve. I didn't take it apart, so I do not know how it was originally. There is an odd number of shims that does not divide be 3, so either they lost some, or one cylinder was different.
Thanks,
JLG SCISSORLIFT (A52705)
JLG SCISSORLIFT...
(2) 7000 8 LUG TORTION AXLE (A58376)
(2) 7000 8 LUG...
2008 DOOSAN G25 GENERATOR (A55745)
2008 DOOSAN G25...
2025 MS380R Mini Stand-On Track Loader Skid Steer (A56857)
2025 MS380R Mini...
Milwaukee Dry Vac (A57454)
Milwaukee Dry Vac...
2020 Topcat 48" Hydraulic Articulating Skid Steer Cutter Attachment, S/N BORC20120101, Asset# 69 (A59076)
2020 Topcat 48"...
