1930 will not rev
   / 1930 will not rev #1
mktchevelle
new holland 1630
I just picked up a 1630 that was not running. I got it running today but it will only idle. It is not the shut off solenoid I can remove that and use a magnetic pick up tool to move the rod on the pump to overcome the governor and it will rev some. Is there a governor adjustment or is something stuck in the governor? Any help would be greatly appreicated .
   / 1930 will not rev #2
Sounds like a fuel volume problem change your fuel filter first under the tank before looking at any injection pump problems.
Altec AM55 55ft Electrically Insulated Material Handling Bucket Truck Body (A51692)
Altec AM55 55ft...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A54607)
2013 PETERBILT 386...
2009 Ford F-550 Auto Crane 4004EH 2 Ton Crane Service Truck (A51692)
2009 Ford F-550...
SET OF (6) LADDERS (A53843)
SET OF (6) LADDERS...
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
CATERPILLAR 631G MOTOR SCRAPER (A52706)
CATERPILLAR 631G...
