1930 will not rev
   / 1930 will not rev #1
mktchevelle
new holland 1630
I just picked up a 1630 that was not running. I got it running today but it will only idle. It is not the shut off solenoid I can remove that and use a magnetic pick up tool to move the rod on the pump to overcome the governor and it will rev some. Is there a governor adjustment or is something stuck in the governor? Any help would be greatly appreicated .
   / 1930 will not rev #2
Sounds like a fuel volume problem change your fuel filter first under the tank before looking at any injection pump problems.
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
More info coming soon! (A53421)
More info coming...
2007 NLB Trailer Mounted Shell Side System (A53117)
2007 NLB Trailer...
2003 Walk-Behind Automatic Seed Spreader (A51691)
2003 Walk-Behind...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
