1938 9N
   / 1938 9N
Sounduy,
Do you happen to know of a good wheel and tire distributor on the net? thinking about offering $500 and see what happens. Atleast then after i replace wheels and tires I should be about in the appropriate price range of a comparable 9N.
Do you think I should put a liquid ballast back in replacement rear tires?
Worst case scenario, if the rake is too heavy, I could just put a 5' or 6' finish mower on it.
   / 1938 9N #12
miller tire is a trusted supplier of tires for many machines. if you order tire/tube/rims combo's.. you used to be able to ge tthem pre-assembled.. a time saver. etc. Incedentially.. those prices i quoted you were from his site.. he's usually pretty cheap. ya might luck out and find a local mom-n-pop shop that might beat them a lil bit.. perhaps a cheaper/less expensive tire.. or rims on hand already.. used set.. or old stock they need moved.. etc.
M.E. Miller Tire
Ballast is up to you.. depends on what yo are doing.. if owing and raking.. i doubt you need ballast. if you were plowing, discing, 9 any ground engagement.. or heavy load pulling ) or had a fel.. I'd say go with ballast.
if i went with ballast.. go with something like rv antifreeze.. I like to use the poly-prop 'safe' stuff. cacl is still cheaper per # than anything else.. but unless you practice judicous care and celan up and fix leaks.. don't go with it.
A averge 9n should run a 6' finish mower decently.. or a 5' rough cut mower.
a good N lift should pick up 800#.. though the front end will get light.. might toss some weight on the front bumper..
soundguy
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
UNUSED LANDHERO MIG-140 WELDING MACHINE (A51248)
UNUSED LANDHERO...
POWER LINE 180 LOT IDENTIFIER 82 (A53084)
POWER LINE 180 LOT...
2009 Jordair Marines-320-DH Trailer Mounted Air Compressor (A51691)
2009 Jordair...
HURRICANE 5' X 10' CONTAINER (A51248)
HURRICANE 5' X 10'...
UNVERFERTH 210 LOT IDENTIFIER 16 (A53084)
UNVERFERTH 210 LOT...
