Hi everyone, I am new here and hope that I can get some help. I have had this 8n for about 5 years and it has run great with no problems. I was using it for about an hour and when i went to stop I had put it in neutral and it continued to go. I moved it a little bit after that and it came to a complete stop. There was no pops or breaks that i could hear. I have been told that it may be in two gears at once. I took the shifter cover off and it appears to be stuck in 3rd gear now. I can not get the upper rod to slide back into neutral. I have now jacked up the back and was told to rotate the tires backwords. When i do that they go in opposite directions. Does anyone have any suggestions.
Thank you for any help that you can give.
