1950 Ford 8N 3point hitch not working right
   / 1950 Ford 8N 3point hitch not working right #1
textedford
mahindra 1626,ford 8n
Hi Guys I have a 1950 8 N that the 3 point hitch dosen't work right. We have replaced the hydraulic pump, upper cylinder, piston ,rings,and all gaskets and the arm that goes thru the big spring on the back, The draft control level(the short one under the right side of the seat)seems to be stopping the 3 point hitch from working unless I strap the lever down real hard. Does anyone know what is happening. HELP!!!
THANKS Tex
   / 1950 Ford 8N 3point hitch not working right #2
Have you replaced the cam follower pin? What you describe is a symptom of it being worn out or missing.
no but i will see if i can find what you are saying thanks textedford.
hi John0829 are you talking about the draft control arm cam pin thanks textedford.
   / 1950 Ford 8N 3point hitch not working right #5
That's the one
thanks alot im going to work textedford.
2019 Polaris Sportsman 450 (A50123)
2019 Polaris...
1996 FORD F SERIES DUMP TRUCK (A51406)
1996 FORD F SERIES...
JOHN DEERE TS 4X2 GATOR (A51406)
JOHN DEERE TS 4X2...
2010 Autocar Xpeditor T/A Labrie CLSFRH 33 CuYd Side Loader Garbage Truck (A51692)
2010 Autocar...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
