1955 Ford 640 Distributor Mechanical Advance
   / 1955 Ford 640 Distributor Mechanical Advance #1
JStorch
Sullivan, Ohio
1955 Ford 640
I ended up as the caretaker for a community owned tractor. She ran pretty good in the 800- 1700 RPM range but wouldn稚 idle lower and was balky at higher RPM痴. Today I put a timing light to her and confirmed the mechanical advance simply doesn稚.
A look inside the distributor revealed 50+ years of rust and assorted goop. I pulled the weights and cleaned them, however before I put them back in I would like to find out what the proper lubricant is for the weights. I have to go find breaker cam grease and may as well pick up the right lube for the weights.
Thanks,
John
   / 1955 Ford 640 Distributor Mechanical Advance #2
that napa ML1 you are putting on the cam lobe is fine for the flywheights too.
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A52705)
2016 JOHN DEERE...
2012 Club Car Carryall 1 Utility Cart (A54811)
2012 Club Car...
More info coming soon! (A53421)
More info coming...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
2019 POLARIS RANGER XP1000 RTV (A51406)
2019 POLARIS...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
