1955 Ford 800, Won't Start anymore
   / 1955 Ford 800, Won't Start anymore #1
Ervin Smith
Foley, MO 63347
1955 Ford 800, 1966 Ford 5000, 1992 White Gt1855 GT2055, Bobcat 753
Turns over good, cleaned plugs, replaced wires, new cap, rotor, and condenser, new coil. rebuilt carburetor when I got it. quit running 5 days ago. sprayed WD 40 into wireing and cap, cleaned out good. and it started and run all day. Restarted just fine in between breaks. next day it won't hit a lick. Any Ideas guys.
   / 1955 Ford 800, Won't Start anymore #2
Why did you undertake the ignition work? Have you done anything odd with fuel lately (old batch, mixed old with new, etc.)? Have you checked the compression?
Jim
   / 1955 Ford 800, Won't Start anymore #3
The old 55 model had points,, unless you changed it over.. pull the cap and see if your points are firing,, if not start tracing it back... that the first thing I would check on an old 55.. Lou
   / 1955 Ford 800, Won't Start anymore #4
first things first.
check spark at all 4 glugs.. should be blue and snappy. plugs gap at .025.
if no spark, check power to coil by hotwireing coil. if still no spark.. put test lamp inline with coil, run starter. lamp should blink. if it never comes on.. you have an open. could be bad points.. could be the conductor from side of dizzy to points broke. look at poitns. of pitted and burned. check condensor... might be open.
if it stays lit.. points are shorted. common area is the feed thru insulator on side of dizzy, slipped points.. and less commonly.. shorted condensor.
points gap at .025
if spark is good.. move on to fuel / air / compression
post back some details.
(2) 330 GALLON POLY TOTES (A51248)
(2) 330 GALLON...
LOT IDENTIFIER 133 (A53084)
LOT IDENTIFIER 133...
2021 JOHN DEERE 8R 340 LOT IDENTIFIER 89 (A53084)
2021 JOHN DEERE 8R...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
14' Bi-Parting Gate (A50120)
14' Bi-Parting...
