1961 massey
   / 1961 massey #1
billgray
roanoke va 24019
1961massey ferguson
my brother has an old 1961 massey that we use on our old homeplace to dress roads ,push snow and pull a log or two. tractor runs ok , but has stopped going into reverse,all other gears work ,any suggestions on how to fix it ?
   / 1961 massey #2
Welcome to the forum. :)
I have moved your thread over to the Massey section to see if someone over there can help.
   / 1961 massey #3
Could you tell us a bit more about this problem. Model of tractor, transmission that is has, and any other details. Does the shift lever not go into the reverse position? Does it go in and no reverse gear engages?
   / 1961 massey #4
Had a similar problem on my MF-65 diesel. The fork was stuck. Had to remove the cover and repostion everything to neutral.
UNUSED FUTURE FT15 EXCAVATOR (A57192)
UNUSED FUTURE FT15...
UNUSED FUTURE FT-ZP20 20' X 30' GARAGE CARPORT (A57193)
UNUSED FUTURE...
2015 Ford F-750 Stellar 10628 10,000LB 5 Ton Mechanics Crane Truck (A55852)
2015 Ford F-750...
QA Hitch Plate (A56469)
QA Hitch Plate...
CATERPILLAR H120S HYD HAMMER (A52707)
CATERPILLAR H120S...
2013 Infiniti G37 Coupe (A55853)
2013 Infiniti G37...
