1961 Powermaster problem
   / 1961 Powermaster problem #1
Neb
Oklahoma
none yet
Hello. My 61 801 Powermaster runs badly under load. I've tried carburetor adjustments per the manual, but runs weakly under load. Was wondering...a few months back, a freeze plug fell out. The tractor got hot enough to run just a bit strangely. Shut it down as soon as it started to run differently. Put in a new freeze plug within a week and it fired up fine. Drove it a few minutes and parked it as I haven't needed it. Time to brush hog and it fires up and seems fine until put under load. Doesn't overheat, doesn't smoke, doesn't sound like the engine has rocks in it, just runs weak under load. Damage from overheating or carburetor our of adjustment? Haven't messed with carb until earlier today though. Sorry for drawn out post. Any advice would be appreciated.
Thank you all.
   / 1961 Powermaster problem #2
Governor stuck or not adjusted correctly? Had an 8n with that problem, wouldn't throttle up under load.
I will look into that.
2006 Ford Fusion SE Sedan (A51694)
2006 Ford Fusion...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB Crane Mechanics Truck (A52377)
2015 Ford F-350...
2020 International MV607 2,000 Gallon Water Truck (A51692)
2020 International...
WHISPERWATT DIESEL POWERED GENERATOR (A53843)
WHISPERWATT DIESEL...
2010 DODGE RAM 2500 FLATBED TRUCK (A51247)
2010 DODGE RAM...
1996 FORD E SERIES VAN (A53843)
1996 FORD E SERIES...
