1963 4000 governor?split tractor or no?
   / 1963 4000 governor?split tractor or no? #1
Old Virginia Joe
Bronze Member
SE Va.
'63 Ford 4000, '48 Massey Harris 30
It has been advised to me by the local shop that my surging problem is due to governor issues. The question is, does this tractor have to be split front from rear to repair the governor or not? Big price difference to fix if so. It is. 4 cylinder gas, 172 engine, wide front end. Thanks.
   / 1963 4000 governor?split tractor or no? #2
Maybe what someone meant by "split" is that you would need to remove the front axle and axle mount. Without looking at it, I can't remember if you would even need to do that.
   / 1963 4000 governor?split tractor or no? #3
No need to split,just move things forward a little on front for clearance while removing timing gear cover. I highly recommend having all the linkage and adjustments checked before going into replacing governor. Now I have a question. Why didn't the shop that started you down this road answer any questions you had about it?
It does appear that the term split-the-tractor was misunderstood. Actually what should have been said was that it needs to have the hood and fuel tank removed and the front axle pulled loose to get at the governor. My mistake in terminology. Still should have been advised when I had the motor rebuilt though and I am angry that I was not so advised by the machine shop. Lots of my precious money is wasted!
6 BENCH GRINDER (A53843)
6 BENCH GRINDER...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53473)
2014 Doyle Dry...
2014 Ford Taurus AWD Sedan (A51694)
2014 Ford Taurus...
2012 WABASH 53' DRY VAN TRAILER (A53843)
2012 WABASH 53'...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A51246)
JOHN DEERE 437E...
