1964 MF135 gas, need voltage regulator schematic
   / 1964 MF135 gas, need voltage regulator schematic #1
wadewells
AL.
M F 135
My old 135 had a GM car voltage regulator for years, now that I have the correct regulator I need a schematic diagram to wire it correctly. I think I can do it but would like to see a schematic to verify. I know it's probably in the manual but rather not wait a week for delivery. :)
Thanks!:thumbsup:
   / 1964 MF135 gas, need voltage regulator schematic #2
What engine do you have? BobG in VA
BTW, a U. S. made Echilin regulator was only $10. more than the fitz-all Chinese part.
OK, have a real problem now. Put the new regulator on and it's charging but as soon as I turn the engine off the regulator gets really hot and one set of contacts glow red.
A=Armature
F=Field
Batt=12V (yellow wire)
L=Lights.
There is a braided white wire from the switch that I thought went to the L terminal, maybe not?
   / 1964 MF135 gas, need voltage regulator schematic #6
http://www.tractorshed.com/gallery/uptest/a53575.jpg
Thank you Kenneth S., I had the thing wired wrong. Had the battery and light wire swapped. All works as it should thanks to the diagram.
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
VERMEER NAVIGATOR 53 D23X30111 DRILL (A51406)
VERMEER NAVIGATOR...
2013 Buick Enclave SUV (A51694)
2013 Buick Enclave...
2025 Mower King SSBM72 (A50123)
2025 Mower King...
Aluminum Boat Top (A53117)
Aluminum Boat Top...
378813 (A51573)
378813 (A51573)
