1966 ford 4000(3 cylinder) problems
   / 1966 ford 4000(3 cylinder) problems #1
Duramax88
Louisville, Ohio
1966 Ford 4000 3 cylinder gas, 2003 Jinma 354 4x4 diesel
Hi
Can anyone tell me where I can get a free exploded view of the distributor for my tractor? The issue I have is the plate that holds the points, and condenser is not attached anywhere and just kind of floats inside. Seems to me there should be screws holding it in place. Just bought the tractor and ordered a manual but haven't received it yet. Thanks.
Thank You. Found it and have used it several times already.
Hi Can I safely (for the tractor) and effectively use a 7 ft 3 point tiller with my ford 4000 3 cylinder gas tractor?
   / 1966 ford 4000(3 cylinder) problems #5
My 4000 diesel handles a 6ft with no problem.
Okay Thanks
2014 Ford F-150 Pickup Truck (A56858)
2014 Ford F-150...
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
New Holland TV145 4wd Tractor (A56436)
New Holland TV145...
20ft Jumper Cables (A57454)
20ft Jumper Cables...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
500 BBL FRAC TANK (A58214)
