1967 JD 4020 powershift transmission sudden failure
   / 1967 JD 4020 powershift transmission sudden failure #1
owens73
Jonesboro, AR
4020 John Deere
I have a front end loader on my 4020 and was using it to push some trees and brush I had cut months earlier. Transmission working fine one second, then moved the gear shifter to reverse and nothing happened. Transmission will not engage in any gear, forward or reverse. Was told of a switch below the rear axle that may have been moved by some of the debris I was pushing. If that's a possible solution and since I'm an hour away from the tractor, I wanted to know if someone knows exactly where this switch is before I go up to work on it. Thanks.
Steve
   / 1967 JD 4020 powershift transmission sudden failure #2
It's not a switch but a disconnect lever for towing purposes. It's located on LH rear of floorboard. Another possibility is a stripped hub on damper clutch at flywheel. This damper clutch also has a disconnect lever(cold weather starting aid) on LH side of dash. Be sure it's not disengaged.
Thanks. I'll try that.
   / 1967 JD 4020 powershift transmission sudden failure #4
Also look at the rear axles where they attach to the wheels. You could have stripped the keyway on one side and the axle would spin inside the wheel without the tractor moving.
   / 1967 JD 4020 powershift transmission sudden failure #5
Do the axles, on that big tractor, really have key ways?
   / 1967 JD 4020 powershift transmission sudden failure #6
Yes the key is built into the wedge. I've never seen one stripped. Another thought is the possibility of a pinion shaft failure in the differential. If tractor has diff lock try depressing pedal ans see if tractor will move.
   / 1967 JD 4020 powershift transmission sudden failure #7
Thanks, Jim. I learn something every day.
JOHNSON OUTBOARD MOTOR (A58374)
JOHNSON OUTBOARD...
Skid Steer 66in Skeleton Bucket (New/Unused) (A59225)
Skid Steer 66in...
2012 FORD F-350 XL SUPER DUTY CREW CAB SERVICE TRUCK (A58375)
2012 FORD F-350 XL...
JOHNSON JW12 OUTBOARD MOTOR (A58374)
JOHNSON JW12...
WATER TRAILER (A58214)
2023 54in Hooklift Dumpster 15 Cubic Yard (A56858)
2023 54in Hooklift...
