1968 massey 135 cont. gas tractor 3 pt lift. slow liftting.
   / 1968 massey 135 cont. gas tractor 3 pt lift. slow liftting. #1
boomer05
bartlesville ok.
suzue m2000
will lift brushhog but is real slow and the levers have to be nearly all the way up to lift.oil is clean.pump circulates a good flow.thanks
   / 1968 massey 135 cont. gas tractor 3 pt lift. slow liftting. #2
Although your pump flow is good, it might not be getting to the 3pt cyl, and if it does, it could be leaking by the cyl seals.
The relief valve might be leaking.
Install a hyd gage and test the pressure while lifting or max out the 3pt cyl and read the pressure.
2018 JLG 20MVL ELECTRIC VERTICAL MANLIFT (A52705)
2018 JLG 20MVL...
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
New Holland TS 75 Front Loader Utility Tractor (A55787)
New Holland TS 75...
2013 Bobcat T180 (A47477)
2013 Bobcat T180...
30pc. 16ft.x 3ft. Brown Metal Roof/ Wall Panels (A53424)
30pc. 16ft.x 3ft...
2025 MS380R Mini Stand-On Track Loader Skid Steer (A55787)
2025 MS380R Mini...
