1969 ford
   / 1969 ford #1
ford1969
custer,wisc
ford/3500/1969
Help, I need help. I have a 1969 3500 industrial tractor that has a 4 speed power reverse that will not go forward. Any ideas.
   / 1969 ford #3
Does it go backwards?
   / 1969 ford #4
Ditto. Does it move at all? either direction?
Also, what does the transmission fluid look like? Clean and proper level?
It isnt like a standard trans where the oil is only there for lube. The PR has a torque converter and relys on hydraulic pressure to work.
   / 1969 ford
Goes in reverse and no forward gear. Also changed out fluid and filter. Old fluid looked like weak chocolat milk
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2015 FORD F550 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F550 XL...
1994 Fontaine 48 ft. T/A Float Trailer (A53117)
1994 Fontaine 48...
SET OF (6) LADDERS (A53843)
SET OF (6) LADDERS...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
